Setting up the animation tables with the words to monitor does give real time values, however would like to display on ladder rung, as i am using pl7 micro version not the Pro maybe thats where my answer is.
Hi.. Even PL7 pro does not give the real time values on the ladder rungs or in the variable tables area (AB and siemens give). Animation tables and dialog boxes for I/o modules are the only way you can see your values in the ladder editor. Regards, best wishes. Raj S. Iyer
