tournier Posted September 14, 2006 Report Posted September 14, 2006 I'm using an Twido Plc with Magelis XBT-N401, comunication cable XBT Z 968, Modbus protocol, but it is no comunication between. Modbus is the only protocol I can chose on both units.Any ideeas? Quote
Crossbow Posted September 18, 2006 Report Posted September 18, 2006 Check for the manuals on www.telemecanique.com. I think you should be able to select Unitelway for this connection, not Modbus. Quote
Ryan1 Posted September 20, 2006 Report Posted September 20, 2006 Hi The cables have changed, you need a xbt9780 and you need to use modbus protocol Quote
tournier Posted September 21, 2006 Author Report Posted September 21, 2006 Thank you for your help, I managed to solve the problem. Once again, thank you Quote
rajsiyer Posted January 19, 2007 Report Posted January 19, 2007 Hi Tournier... Exactly the same problem I'm facing with XBTN400(2). I'm struggling to achieve communication betwween the Twido PLC & XBT. Can you explain what exactly you did. I'm eager to know. Regards, Thanks and best wishes Raj S. Iyer Quote
asim_rana Posted January 26, 2012 Report Posted January 26, 2012 Hi raj Did you manage to communicate them(Twido & XBT).Below is waht i did but still not abale to get it done I HAVE A MAGELIS HMI XBTG4320 AND A TWIDO PLC TWDLCDA24DRF.I HAVE FOLLOWING DETAILS: HARWARE SETTINGS::: 1-I AM USING TWIDOSUIT FOR PLC AND VIJEO DESIGNER FOR HMI. 2-I AM USING DOWNLOADING CABLE FOR HMI "XBTZG935" (PC)USB<------------------>USB(HMI) 3-THE CABLE B/W PLC AND HMI IS "XBTZ9780" (PLC)MINI DIN<----------->RJ45(HMI) SOFTWARE SETTINGS::: PLC: 1-OPENED TWIDOSUIT AND IN WORKSPACE OF DESCRIPTION I DRAGED AND DROPPED TWIDO PLC TWDLCDA24DRF AND CLICKED ON TWIDO PLC AND SETTED THE TYPE MODBUS AND ADDRESS AS 1 (Slave). 2-SIMILARLY I DRAGED AND DROPPED MAGELIS HMI AND MADE ITS SETTINGS AS MODBUS Master AND ADDRESS 0(Master) 3- I JOINED THE MIN DIN CONNECTOR OF PLC WITH THE HMI,SO ON WORKSPACE IT SHOWED ME"MY NETWORK 1 ,19200" ,PARITY=EVEN,STOP=1,DATA BITS=8 4-IN PROGRAMMING OF PLC I DIRECTLY ENERGIZED %M0 --------------------------------(%M0) 5- I DOWNLOADED THIS PROGRAM ON PLC. HMI:: 1-OPEN VIJEO DESIGNER CREATED A PROJECT WITH NETWORK AS MODBUS RTU AND SLAVE EQUIPMENT "1" AS TWIDO PLC ADDRESS IN ABOVE PLC SETTINGS IS MADE ONE(CHECK STEP 1),XBTG MODEL=XBTG4320, 2-SETTINGS ARE ALSO LIKE THEIR IN PLC BAUD RATE 19200,PARITY=EVEN,STOP=1,DATA BITS=8,COM PORT=COM2 3-CREATED A VARIABLE WITH TYPE=DISCREAT, DEVICE ADDRESS %M0,SOURCE=EXTERNAL 4-I M JUST CREATED A CIRCLE AND IN ITS VISIBLE TAB I CHECK BLINKING ANIMATION AND AND SELECTED THE VARIBALE %M0 WHICH I CREATED ABOVE CONCLUSION: I HAVE DIRECTLY ENERGIZED %M0 FROM PLC AND ALSO CREATED A VARIABLE %M0 IN HMI AND TAGGED WITH THE BLINKING CIRCLE AND SELECT COM 2 IN HMI.BECAUSE COM2 IN HMI IS CONNECTING HMI ITSELF AND PLC THROUGH CABLE XBTZ9780 AS I DESCRIBED IN HARWARE SECTION.NOW WHEN I DOWNLOAD THE PROGRAM IN HMI,THERE IS A CIRCLE BUT ITS NOT BLINKING,AND AFTER SOME SECONDS IT SHOWS TIME OUT NO RESPONSE FROM PLC. NOW BROTHERS HELP ME OUT WHY THIS IS SO.WHY %M0 IS NOT LINKED Quote
