Hello. I'm having problems writting in locations DM 6550->DM6559 (com port settings) Problem is, that I can't write to this locations. I'we got the following error: ERROR: Operand 2 out of range at rung 0 ( 6, 5 ). Is there somekind of sollution to this problem? I would really like to work with CX-Programmer. THX.
You can not use MOV instructions to write to the setup area. What processor are you working with. There maybe a different instruction that is used to change the port settings from your ladder program. Hope this will help.
You can open "memory" on the left hand side of the screen when on line and write directly to the DM area.
