mr_shadow Posted September 21, 2006 Report Posted September 21, 2006 Hi all; I'm a new user of mitsubishi and i'm trying to program GOT1000 but i don't have the original programming cable i made a 5 meter cable with the connections like below female1 female2 2------------------->3 3------------------->2 5-------------------->5 4--------------------->8-6 (8 and 6 short circuit) 8-6 --------------------->4 (8 and 6 short circuit) Is that connection true?because i don't have enough time to wait the original cable if it is true or if i made the true one what must be the communication settings of COM port of PC. Because when i try to test the communication in the GT-designer VER2.27 it says you couldn't establish a communication Check the cable or check the port settings, but as there is no STANDARD OS in the GOT i couldn't check the port settings of GOT. Is it possible to see these settings without a STANDARD OS. If anybody help me withe this problem i will be happy. Quote
waynes Posted September 22, 2006 Report Posted September 22, 2006 mr shadow, The best to use is a USB cable. These cables are available at a normal PC shop and will allow much higher communication speeds to/ from the GOT. Also, using the USB will allow you to still interface to the PLC through the GOT. Regards, WayneS Quote
Gambit Posted September 22, 2006 Report Posted September 22, 2006 I agree a USB cable is much easier. If not you probably need the following cable It's for connection a GOT1000 to a Mits PLC via RS232 but that has the same port as a PC. Quote
Trisno Posted June 10, 2019 Report Posted June 10, 2019 hi mr. shadow, the connection that you mention above is true, i have tried follow your explanation is works. prwviously i have same problem ,now is solved. Quote
