Hi, The instruction differs between the different ranges. Which PLC range are you using? FX2N System Q FX3U?
Great, That helps. Follow this url to download the FX2N manual. Goto 5.9.8 (or page 248 of 468). The PID instruction is there with all of its parameters. I can send you some of my PLC code that has this instruction configured and working correctly. Edit: OK, I attached an example. PID_Example.zip Edited by waynes
  • Like 1
