Hi I am using a Modicon PLC and tried to connect Siemens TP270 Display via Modbus interface to That PLC , But now Please tell me how much is the Standard Cable Length For Modbus Interface ? and which Convertor Modulle i must use to chang My Bus from Modbus to Modbus+ in order to increase the cable Length ? Thank you so much
The only way to get Modbus devices on Modbus Plus is with a Modicon Bridge Plus. That Bridge Plus connects Modbus serial devices to Modbus Plus network. It's not a cheap connection either, as Modbus Plus is a proprietary high speed bus (similar to AB with DH485). You're probably best leaving the interface on RS232 which typically can't be more than 15 meters.
