Controller Posted October 16, 2006 Report Posted October 16, 2006 Guys, I'm trying to connect one TSX Premium with one PC. I will use ethernet radio modems from Data-Linc (SRM7210E). I want some advice to choose the module I need to buy. I have note applications from Data-Linc wich show this application using the module TSX-ETY-110-WS. However I have seen the TSX-ETY-110 (class A10) at really low price, but I do'nt know if this enough to do is what I need. I want to monitore the process (see the process data... actually this data is read through the serial port) but also I would like to programming and/or configure and/or diagnostic the PLC at the same time (it means run the SCADA application and the Programming softw). Configuration of the PLC is as follows: 1)TSX PSY 5520 2)TSX P5720 3)TSX DEY64D2K 4)TSX DSY64T2K 5)TSX AEY1600 6)TSX AEY1600 7)TSX ASY410 8)TSX ASY410 9)Free 10)Free 11)Free May you please indicate if the TSX-ETY-110 is good enough for this...or I would need the TSX-ETY-110-WS or another ethernet module. Thanks in advance for your kind support. Quote
Crossbow Posted October 18, 2006 Report Posted October 18, 2006 The WS model has some basic web server functions. I've never seen one without the WS in the part number. I know they were replaced by the TSXETY410 and TSXETY510 a few years ago. So the 110WS is really old. Quote
