I have a S7-200 PLC and would like to use a Sportster modem to remot to it, is this possible. Do I just the need the programming cable and a 9 Pin to 25 Pin adapter? All the info i see shows using a EM241.
The EM241 modem module is the easiest method since there's a wizard built into the software to configure it, and there's no cables to mess with. And it has support for things like SMS messages to cell phones for alarms. Used one on a water treatment system to call the manager in high water alarm and for remote dial-in maintenance.
