Guapo Posted October 26, 2006 Report Posted October 26, 2006 Hi, to everyone! I'm new here! I want to create my first STL program for FX2N, but it's not clear how to do that. So anyone who can send me an example, please do it! Thanks! Quote
Goody Posted October 26, 2006 Report Posted October 26, 2006 maybe you should look around - maybe in the download code section Quote
Crossbow Posted October 26, 2006 Report Posted October 26, 2006 There is a discussion on STL programming in the FX Programming Manual. If you're using FX2N, go to the downloads section or www.meau.com and get manual JY992D88101D. There's an entire section on it. Quote
Guapo Posted October 30, 2006 Author Report Posted October 30, 2006 Hi Crossbow! I just did it, but I already read it. My problem is, that I can't do the same on GX developer screen, which is on the pages of the manual. For this reason I asked some practical exaple (sample code) in real STL code. I only want to see it on my GX runs! Quote
Goody Posted October 30, 2006 Report Posted October 30, 2006 I did a small program in STL for you to download. And you are right, the book is outdated as it does not show STL as it is really programmed. Quote
Crossbow Posted October 31, 2006 Report Posted October 31, 2006 What do you mean you can't do it on GX-Developer? Can you be more specific what you can't do? The code works, I've typed it in before to test. Quote
Guapo Posted November 19, 2006 Author Report Posted November 19, 2006 I have left STL It was too much work, without any advance. Thanks for that helps! Guapo Quote
