Sima Posted November 1, 2006 Report Posted November 1, 2006 Dear Engs. who know why i've the next problems: 1- When i try to connect to CPU311D with Versa pro 2.0 the communication is interrupter and display the next ( a time out occurred while trying to connect to the plc ). 2.- I connected with the logic master; and i can created a subrutine with this, but when i run the plc, doesn't has out signal (tHE MODULE MDL740 HAS 24VDC). Someone could tell me how i can fixed these ploblems or one of them. Thanks. Question; when the Power supplier no on the green led of OK. the cpu is burn or we can reset this. because i've the original cpu (cpu311L) where the problem began. Quote
Smoke Posted November 1, 2006 Report Posted November 1, 2006 (edited) Do you have the new subroutine called? Edited November 1, 2006 by Smoke Quote
