electroniz Posted November 2, 2006 Report Posted November 2, 2006 I'm looking for the software and cable to configure the Panel View PM PLUS 1000. Who can help me about this?
jerjo2 Posted January 31, 2007 Report Posted January 31, 2007 I've got the software you need (DOS) but I don't know if it is OK to send it to you because of copyright protection. Perhaps anyone else can tell me if it is OK? I can also give you a description about the cable. jerjo2
TimWilborne Posted January 31, 2007 Report Posted January 31, 2007 A description of the cable is fine but no pirated software TW
Scadaman Posted July 4, 2007 Report Posted July 4, 2007 A regular DB-9 cable should work. The programming PC is a DTE device. The Panelview Plus 1000 is a DCE device. You connnect a DTE device to a DCE device using a straight-thru cable.
Crossbow Posted July 11, 2007 Report Posted July 11, 2007 Cutler Hammer might give you software for those units if you are converting them forward into new Panelmates, I don't recall it's been years since I worked with one.
Steve Bailey Posted July 11, 2007 Report Posted July 11, 2007 You can download the DOS software for the PanelMate 1000 here: http://www.eatonelectrical.com/NASApp/cs/C...rsion+Utilities You will have to have a computer running Windows 98 or earlier to use it. I think it will work for the PM Plus 1000 as well as for the standard PM1000. As far as I know, the only difference is that the PM Plus 1000 was brand labeled for Modicon. Back when I worked for a distributor that sold PanelMates, the PM1000 software included drivers for all available protocols except Modbus RTU. We had to charge extra for that. The Modicon distributors sold software that included RTU as standard, but they had to charge extra for drivers for any other brand.
Special Edward Posted November 27, 2007 Report Posted November 27, 2007 (edited) I have the VCP1000 software and the drivers. Should I be downloading more than one driver plus the configuration? If yes, is there a particular order? Edited November 27, 2007 by Special Edward
Steve Bailey Posted November 28, 2007 Report Posted November 28, 2007 You only download one driver. Download the driver first, then the application. Once the driver is installed on the PanelMate, when you make changes to the screens, you don't have to re-download the driver. So, before you download anything, check to see what driver is already present. If it is the same as what you intend to use, you only need to download the application. I say this because downloads on the PanelMate 1000 are painfully slow. A driver download might take 15 minutes.
