trickster Posted November 15, 2006 Report Posted November 15, 2006 Hello all, I'm new to explicit messaging. I can't seem to find much documentation on the web about it. Does anyone know of any sites or pdf's that explain the diffences between the services, classes, and instances - and explanations of what each is actually used for? I get most of the services, it's pretty self explanatory - I think - but the Class and Instance fields are somewhat more difficult. I'm using devicenet and the program is SST Devicenet Configuration. I appreciate any help. Quote
Smoke Posted November 16, 2006 Report Posted November 16, 2006 Here is some info if you will go to rockwell automation knowledgebase and search "devicenet messaging examples" you can find more info. Basics_of_Explicit_MessagingV3.doc Quote
