redfred1 Posted November 16, 2006 Report Posted November 16, 2006 I am still using Proworx NxT version 2.20 and a Quantum 113/3. I would like to trigger an event at 5 am and 5pm. There doesn't seem to be a compare that will look at the clock registers and pass a signal to trigger a bit. I must be missing something because that should be an easy function. Thanks, FredD Quote
Derickvdw Posted November 19, 2006 Report Posted November 19, 2006 Why don't you use the test funtion block. One that reads the hour register, test it against a fix value of 5 ond then give you an output. do the same with another block but for 17. Sure that should do it Quote
redfred1 Posted November 20, 2006 Author Report Posted November 20, 2006 Thanks Mate, I'll try it! FredD Quote
