rpraveenkum Posted November 30, 2006 Report Posted November 30, 2006 search Function in the forum is not functioning or i don't know how use search function Quote
TimWilborne Posted November 30, 2006 Report Posted November 30, 2006 THIS thread will help you. Note the "*" on 3 letter words TW Quote
rpraveenkum Posted November 30, 2006 Author Report Posted November 30, 2006 Iam not getting correct post liking to autocad topic Quote
TimWilborne Posted November 30, 2006 Report Posted November 30, 2006 Can you explain your problem a little more? HERE are the search results I get for "autocad" in the General Topics and it's sub categories Is it that you are not getting results from the subcategories? Quote
TimWilborne Posted December 1, 2006 Report Posted December 1, 2006 No problem. The search is hard to get used to TW Quote
rpraveenkum Posted December 11, 2006 Author Report Posted December 11, 2006 still using search function is hard searching for PLC results in http://forums.mrplc.com/index.php?act=Search&CODE=01 Quote
TimWilborne Posted December 11, 2006 Report Posted December 11, 2006 What was your search string? Quote
Ken Moore Posted December 11, 2006 Report Posted December 11, 2006 You can also use google to search a specific site, use the following syntax: SLC site:www.mrplc.com This tells google to search for the term "SLC" at the specified site : "www.mrplc.com" Quote
rpraveenkum Posted December 12, 2006 Author Report Posted December 12, 2006 Search function not happening for single word like"PLC" Quote
BobLfoot Posted December 12, 2006 Report Posted December 12, 2006 I use PLC* and found this post and several others. Have you tried adding the wildcard * to end of 3 character search. Quote
rpraveenkum Posted December 12, 2006 Author Report Posted December 12, 2006 I wiil try it............ its working . . . . . ha ha ha Quote
BobLfoot Posted December 12, 2006 Report Posted December 12, 2006 I had same issue about a month or two ago. If I could find that post I'd link these two. Quote
TimWilborne Posted December 12, 2006 Report Posted December 12, 2006 Bob, I thought you had this search method down http://forums.mrplc.com/index.php?showtopic=8261 Quote
