Derickvdw Posted December 8, 2006 Report Posted December 8, 2006 I'm wondering if any body knows of software that is used to convert a CAD file into some sort of file that can be used in PLC or MMC controllers. Quote
panic mode Posted December 8, 2006 Report Posted December 8, 2006 MMC (MultiMediaCard) can store any type of file but what are you trying to do with it? use it for what? as a backup of the drawing set or maybe use PLC to read and interpret files? what exactly youare trying to do? Quote
Derickvdw Posted December 9, 2006 Author Report Posted December 9, 2006 MMC stand also for machine & motion controller. I would like to know if I can export a drawing from Autocad into a machine so that machine can use the drawing to control axis. Sort of like a CNC but controlled by PLC or MMC Quote
TERdON Posted December 10, 2006 Report Posted December 10, 2006 You could get a NC machine to do that, using CAM software. I'm not aware of any solution to do it on a "bare" PLC or motion controller though. Quote
