How do I Transition from one sequence to another
you still did not describe problem. what is preventing you from doing that?
each block of instructions is executed top to bottom (begin to end).
sequences are just connecting end of one block with begin of next one.
  • Like 1
Ok so the code is using  EnableRel.DC[myDC] to go from one sequence to the other with RequestRel.DC[myDC] := FALSE   then later in the code when it is being used  := TRUE
so essentially what I am asking is what does the Enable and Request do in the code?
Using Structured text the code has 2 main sequences
which are labeled
mySeq                    := 6; and
 mySeq                    := 3;
I am trying to add a sequence in between for example
mySeq                     := 4;
The problem is, it does not recognize it after i rebuild it. Could this be due to a handshaking error between the sequences?
