Hello
What the program code should look like to be able to change the K variable, the one in the attached picture from the got1000 panel, TO ENTER the values 1,2,3,4 etc.
Needed to select data from the Servo mr-j3-b parameter table.
regards
The value of constant K can be mdified by V or Z index register (K0V1 or K0Z1). While easier way is to use D register instead of K constat.
  • Like 2
