Easiest I know is to use the move instruction.
MOV K2M0 D0
This moves 2 nibbles (K2=2 nibbles=8 bits) starting at M0 to D0.
  • Like 1
@CangkeMan You should use SMOV or AND data with H0F like this
Assume that data in D0 and destination are D10
-| M0 |------[SMOV D0 K2 K2 D10 K2]
or use "AND" function
-| M0 |------[WAND D0 H0F D10]
  • Like 2
@Wasan I didn't find SMOV instruction, I use Q01UD PLC.
So i use serial to communicate with some devices. the device can't accept null data (which is one ASCII Character 8 bits data) in the middle or front in the row data of the  device format requested. null data must be behind CR in order to be read by the device.  how can i move the data 8 bits forward ?
https://drive.google.com/file/d/1SdY9aCKCJx5YcUwinYg31LIsBFEEQX2d/view?usp=sharing
