Problem:
I am getting a control sync fault on 2 recently installed kinetix 5500 but only when my programing PC is connected to the machine network.  Install and setup all went great over a 5 day period.  Then all of a sudden I started to get this fault. Sometimes 100 times in an hour.  As soon as I go offline, and unplug my PC the problem goes away.  I have also tried another PC connected to the Machine network and still get the same result.  Sometimes machine can run for hours with my PC connected with no problem.  I do not have to be online with controller for fault to occur.
Setup:
I have the 2 K5500's ethernet ports daisy chained together, and then connected via shielded CAT 6 cable directly to port 2 of the Compact Logix Controller
Coarse Update is set to 3.5ms and utilization's are at 33% and below.(I have tried the default 2ms with same results)
Ethernet modules are configured with FW rev 7.013.
Machine network is isolated.(not connected to plant network or internet)
Equipment:
Compact logix L33ERM Running version 30.01.
There are a total of four servos in this system all running over ethernet.  2 Kinetix 350's(not affected), and 2 kinetix 5500's.
I have tried:
separate ethernet cables for each drive ran through a switch
different ethernet cables
resetting coarse update speed
connecting a different PC for programming
I am just not sure where else to go with this.  Thanks in advance for any help.
Those devices expect to be in a Device Level Ring.  Without completing the loop, they'll run as a degraded DLR.  Your laptop doesn't do DLR, so plugging it in breaks the DLR's timing guarantees.  Add a DLR-compatible switch, complete the ring with that switch, and plug your laptop into that switch.
Thank you for the advice. Unfortunately this did not solve the problem.
According to the the AB rep these drives do not require a DLR and will run perfectly fine in a linear/star network.  I have seen this in multiple cases myself. (up to 7 drives daisy chained together)
This problem seems to relate specifically to the Dell computers we are using to program with.
Only advice they could give me is that there is software running in my system tray that can affect the time stamp or synchronous settings.
anyone have any idea of what software can do this?
so it appears it was a rslinx version issue with windows 10.  I updated from 4.11 to 4.31 and have not got a control sync fault since.  I will update the thread if I see the error again.
K5500 don't need to be on DLR. Interesting that upgrading RSLinx fixed the issue. Nice find. I would look at the motion timing statistics in Studio to see collect data with this issue. Too much jitter will cause a synch fault.  I use FactoryTalk  Updater software (Free) to notify me when Rockwell's PCDC site has newer versions of software so you might be interested in that.
There are many on the knowledge base site. Some are tech connect so I don’t think I can post those here. Just search the fault name or number. My experience is that synch issues are caused by devices between the controller and plc. Check switches are set up with PTP, enable time synch with any enet modules. Things like that
I personally I have went through all the techconnect notes on knowledgebase and tried all of their solutions to no avail.  Problem has returned but it is 100% limited to workstations(Dell Precision 5820) we are using to connect to the PLC's in affected systems.
I am currently using a Panasonic tough book and have had no issues what so ever.
@Twigums   We are experiencing some control sync faults and can't seem to find anything that might be causing this.  It comes and goes so the thought that it could be something from RSlinx and a certain pc when programing is intriguing.  Did you find anything from AB on this?  How often were you getting the control sync faults with the PC online with the plc?  Was it only when online or did they need to be making changes?  Any insight you can share would be appreciated!
