Yuto24 Posted August 25, 2023 Report Posted August 25, 2023 Greetings! I need some help. I want my timers have the 1ms speed so have a real time second counter, but I cant find the option on the GXWorks3. It's for a FX5U Quote
Gambit Posted August 29, 2023 Report Posted August 29, 2023 Low-speed timers, timers and high-speed timers are the same device. The timer is specified (by instruction) as a low-speed timer, timer, or high-speed timer. If for example, you specify "OUT T0," the timer is a low-speed timer (100 ms); if you specify "OUTH T0," it is a timer (10 ms); if you specify "OUTHS T0," it is a high-speed timer (1 ms). The same goes for retentive timers. 3 Quote
Yuto24 Posted August 30, 2023 Author Report Posted August 30, 2023 Thanks a lot! On 29/8/2023 at 2:02 AM, Gambit said: Low-speed timers, timers and high-speed timers are the same device. The timer is specified (by instruction) as a low-speed timer, timer, or high-speed timer. If for example, you specify "OUT T0," the timer is a low-speed timer (100 ms); if you specify "OUTH T0," it is a timer (10 ms); if you specify "OUTHS T0," it is a high-speed timer (1 ms). The same goes for retentive timers. Quote
WattUp Posted September 5, 2023 Report Posted September 5, 2023 Somehow i never knew about THS option. Good to know! Quote
