xcyong89 Posted November 26, 2023 Report Posted November 26, 2023 Hi All,I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data (Not #COM) in runtime.The setting of SCADA and PLC shows below:a. Omron CJ2M CPU35 built in Ethernet CJ2M-EIP21 - Unit 0, Node 10, Network :1, IP Address: 192.168.1.10, FINS/TCP Port: 9600.Declared Symbol: A_Test_AI1, INT, D501, Publicationb. Aveva Plant SCADA 2020Network Address: 192.168.1.1{Boards} Server Name: IOServer1, Board Name: BOARD1, Board Type: TCP/IP, Address: 0{Port} Server Name: IOServer1, Port Name: PORT1_BOARD1, Server Name: IOServer1, Port Number: 1, Special Opt: -I192.168.1.10 -P9600 -T{IODevice}: Server Name: IOServer1, Name: Omron_PLC, Number: 1, Address: 1/10/0/V, Protocol: OMFINS3, Port Name: PORT1_BOARD1, Automatic Refresh: TRUEDeclared Variable: A_TEST_AI1, Cluster1, Omron_PLC, INT, D501{Citect.ini}: [OMFINS] Source: 1/1/0I able to ping 192.168.1.10 (PLC IP address) from SCADA PCFrom Kernel, I have error message below:Error: Unit offline UINT 000c PORT1_BOARD1 Omron_PLC Error_in_CMD-3 16 Generic 000012 Driver 0000022 (0X00000016)Appreciate that if anyone can give some hint to solve the problemThank you in advance Quote
Wasan Posted April 11, 2024 Report Posted April 11, 2024 Have you try this[OMFINS]Source=1/1/0Block=256 and check that your firewall have block port TCP:9600 or not. Quote
