I am new in this PLC , but i have a good experience in Foxboro Evo & Triconex  .
if I need to check and power up the system , and check if the project file downloaded or not what is the procedure & what is the tools needed , such software and hardware .
To answer your questions.
1. You can power up the system and place the CPU Module Keyswitch in RUN to test if the controller has a program and is runnable.  Fault LEDs will flash if the program is missing.  A check of the manual will tell you more about this.
2. You'll need RSLogix Version 20 and an ethernet or serial cable connection to view the executring logic.
As an Extra Note -
An ACD file is the type used by Rockwell Software for it's Logix 5000 controllers.
"dirty little secret" about ACD files, you can open them with notepad and read the headers.  Often Quite informative.
NOTE: DO NOT EDIT OR SAVE WHILE IN NOTEPAD OR YOU"LL CORRUPT THE FILE
Your particular program was created 2013-04-30 11:45:00.153 and uses version V20.01.00/3489.000 of the software.
The last updates were made 2013-05-09 13:53:12.031: Saved - V20.01.00/3489.000.
As an Extra Note -
Thanks , one more questions , Regarding hardware configuration , will be done also in ACD file , no, of modules type , what about default IP .
Could you please share with manual .
Thanks
Thanks
1. Hardware Configuration is done through the software as well.
2. Default IP can be done through software or possibly through switches on Ethernet Card.  Model Dependant
3.  Manuals - https://www.rockwellautomation.com/search/ra-en-US;keyword=ControlLogix%25205570%2520Controllers;startIndex=0;activeTab=Literature;spellingCorrect=true;facets=;languages=en;locales=en_GLOBAL,en-US;sort=bma;isPLS=false;sessionID=d77ed271-0697-bfda-1db3-bfcf1890068c;deepLinking=undefined
