Morten Posted May 23, 2017 Report Posted May 23, 2017 (edited) Hi I'm all new to using omron but "stuck" with a project. I find the CX Programmer software (version 9.35) a bit confusing. Used Siemens a lot. What I'm trying to do is to display date and time on a HMI showing cpu startup time. I use a "First cycle flag" that triggers once when CPU starts and then I understand that the date and timestamp is in the system variables A352 and A353. But how do I format them as a normal text? I only manage to display them as #hex-numbers. I have tried googeling but have not found an answer to my questions. edit: CPU type is: CJ1M CPU12 //Morten Edited May 23, 2017 by Morten Added cpu type
Mendon Systems Posted May 23, 2017 Report Posted May 23, 2017 There is a function block posted here to do it. I haven't tried it.
